it’s live and thx to TE its now possible to put in chords on a per step basis, from an external controller, while the sequencer is running without holding or activating record. thank you @tngjonas
best is to describe some kind of your setup and what scenario isn’t working at all, otherwise the best thing is to make a short video and send it over to TE and they’ll investigate if it’s clear what’s exactly happening
Anyone noticing dropped steps on BD? I’m noticing BD on first step dropping out randomly occasionally on different patterns and different projects. It happens on patterns newly created or old patterns created prior to the update. Sometimes it loops around fine, but every now and then the first BD is missed, almost seems like a voice stealing issue.
It might be a coincidence but I was having a similar issue but with sending midi from the BD track instead. I was getting skipped notes and it wasn’t sending note data properly. I thought it was an issue with my oplab but switching the midi to track 8 seemed to fix my issue.
I wasn’t using any midi, just internal sounds, and no midi connected, but your post seems to indicate that this is a trigger issue rather than a voice issue, probably worth keeping an ear open to see if it returns on your midi setup too, I find it to be a pretty intermittent, which are always the worst kind of bugs to squish.
