Sup people!?
I’m able to change between the 3 sample play modes while I’m in sample mode (stop + rec).
Green - trig
Purple - gate
Yellow - Loop (default)
I want gate. I set 2/3 samples while in sample mode and it works perfectly. I know my samples and can tell one is cutting another off and it’s working great.
I then return to play mode or whatever the normal, play the OP-Z mode is and boom, no gate. Samples do not cut each other off or act the same way in sample mode :thinking: they actually act is if loop (yellow) is set.
I tried setting samples to trig (green) and leaving sample mode. Boom, works as intended. Sample only sounds as long as you push a key.
Set to loop (yellow/default) and sample plays w/ 1 push of a button or loops of held.
Set back to gate (purple) & basically acts the same as loop/yellow.
Can anyone confirm if this is happening on your unit or if I’m a dingbat lol!? My thought process is that gate is essentially like a choke, this creating a choke group like older samplers. I’m understanding gate to work the same as loop rn and it can’t be right... right???
Ty in advance
