My OP-Z can’t connect to my iMac. Nothing shows up.
Can anyone shed some light on why this may be happening?
I also have not updated my firmware (due to this issue) and I assume I ned to connect the OP-Z to the computer to drop the update in?
Any help is much appreciated.
Cheers.
Hold the screen button while turning on. That is update mode
By doing this, will it then be able to connect to the computer?
Yes just connect the usb c to usb a to the imac.
What are you trying to do once it’s connected to your computer? The manual has all the instructions you should need - https://www.teenageengineering.com/guides/op-z/disk-modes
I’ve updated the firmware and it’s now working fine. Thanks everyone. Still very much learning with this device.
