So I’d like to know whether it’s possible to sync OPZ as slave to OP1 via Line module (trig in channel)
not via USB: it’s for korg nano kontrol
and not using OP1 as slave via Line midi out: it’s for modular synth
Just tried and no it doesn’t work. The op-1 and op-z modules only have PO sync out which doesn’t help in your case.
It should be possible ,the line also has trig in and out next to the po out.
The manual is needed with setting it up.
My bad you’re right! Had to set the step length to 0 to have it listen for triggers. Will need a y-cable to split the PO-sync on L and OP-1’s audio on R.
Edit: wanting to add a few findings in case these impact what you’re trying to do:
Wow! Thank you! Gonna buy a y-cable and try it my own!
