OP1 Custom Firmware -Creative Playground- : Designs, Ideas and Dream-ups
Hey, I start this threat as a place for everyone who enjoys dreaming up new possibilities for the OP-1!
Share your designs, feature ideas, plugin concepts, wild experiments, or whatever comes to mind.
Whether you can code or not, everyone is welcome. This is a place for imagination, no technical feasibility needed, but also welcome.
Devs are warmly invited to explore the ideas shared here and find inspiration for their own plugins and creations!
Have fun!
Thanks for this! I’m really interested in making an engine that has ascii art as the visuals. Will start working on it next week.
Hey, here some graphics, use them for your liking or as basis/inspiration for your effect interface. They’re more ideas than actually finished .svg’s. The name and the functions are just generic suggestions.
Beacon
beacon-final-clean-rings
Resonator:
resonator-ohne-gruene-halbkreise
Reactor:
reactor-cooling-striped
Control the nuclear reactor: Blue controls the amount of coolant for the fuel rods. Green sets the amount of radiation leak and lets the trees grow quickly. White raises or lowers the fuel rods, maybe with some unpredictable algorythm. With red you control overall heat. - if all is cranked to Max, but Cooling water is set to zero, it results in a reactor blast.
Time Chamber
time-chamber-preview-v9
The amount of time controls the age of the chamber. Diffusion is next to the mix ellipses. Tone controls the fire in the bowls. In total it’s 4 images with fix jumps in time value from 0-30-60-90
Deep Field
Field
deep-field-hubble-parameter-demo
Summit
delay.
The gondola represents the echo in a kind of amplitute swing: the initial sound starts its swing, repeats drive it back and forth, and movement settles as the echoes fade.
  • TIME determines spacing between repeats and swing events.
  • FEEDBACK determines how often and how long the gondola is swinging.
  • WOW / FLUTTER adds cable wobble, and vertical bouncing.
  • AGE shows mechanical wear on the gondolas axis.
  • All dials cranked out to Max let the passengers fall out of the gondola.
The further you dial, the stronger the motion The passengers react to the shaking and grip the cabin walls at intensity.
Shore:
The idea is, that every Wave resembles an for example, an Echo wave and is attached to its behavior (at least should be as far as the svg does work) Increased time and Feedbackshould result in more and longlasting Waves. Wow and Flutter is resembled in more pits and Tales behavior of the Waves. With higher Age, the sun is Setting, Stars occure, and the leaves of the Palms Hang down as there is less light.
Example of Wave behavior:
Master Monitor: Headphone EQ with crossfeed
Monitor:
master-monitor-op1-preview
You could load a headphone target curve like from ‚Auto-EQ’. When pressing shift the encoders change to: band-gain-Frequency-and Q, for tweaking a little to taste.
Great​:smiling_face: really exited about it​:fire::fire:
This one is so good
This artist has been inspiring me for a long time: https://joninscii.com/
it’s a great fit for cute OP-1 engines
excellent art mate!
I think I’ll just commission artwork from him. It’s so good
Really love that style of his​:smiling_face:
Thanks​:smiling_face: maybe some still quite steep for OP’s CPU. I think of reshape them to a lighter version
Idea for a Boss SP202 Dr sample inspired drum sample engine:
OP202:
OP-202_Prof-Sample_GIF_Encoder_bleiben_stehen
Blue controls volume, Green sets the Effect per key, red controls Control. The white encoder sets the programs beneath. White plus Shift scrolls through the program’s menus. You can adjust every key of the keyboard by pressing it to select and make your adjustments - The original „bank ABCD" of the Boss is replaced for an Info which key is pressed and effected.
Alternatively pressing white repeatedly could scroll through the program’s menus.
Not sure if it was possible to mimic the beefiness and crunch of the beloved sp202.
Oh my!!! This looks gorgeous
It would greatly free pitch from time, also​:smiling_face:
As a lover of MaxMSP this makes me very happy to see. Not an OP-1, but the potential is there: little-scale on X: "I made an FM1 RNBO patch interpreter which covers 194 RNBO objects, 150 gen objects and the usual patching structures. Compiles input .rnbopat files complete with a visual diagram of the original patch and access to 8 params via the knobs and note events via the keyboard." / X
sorry X link… Little scale is a beast. Their Sega Genenis music tracker is insane too
this would make a banger plugin.:fire:
Yepp! Also for prototyping stuff. As I mentioned in discord I love MaxMSP so being able to test on an OP-1 before without any extra steps is a dream.
a dream I’m sure will soon become reality​:face_with_hand_over_mouth:
Think you’re in the wrong channel @BarneyBrown :nerd_face: Unless not being able to upload your own plugins is a dream update :sweat_smile:
i´m just tired about this constant joking about the “other” firmware, it´s just embarrassing, honestly-– and that goes for both sides. i´m too old for this.
Hello @rackes this is joke about a missing feature being reported in a thread for ideas. Not a joke about specific firmware. I would make the same joke about OPUS and my own synth engines.
However, of course I’m aware that I have had to call out some stuff which resulted, and this is also my own doing, in some users thinking I only shit on HK.
If you would like to have a chat feel free to PM me or use the designated CFW Gossip thread. Happy to listen to you and learn.
As it’s a so cool thing that we all have the og. FW unbound to be customized, and we’re all in just the beginning phase of that fast evolving first aera, this ranting about the other firmware thing is worthless and doesn’t make any sense at all. Hundekraft, OPUS, OP1R, Silvertape and all the other FW’s out there are really really great and astonishing outcomes in general and in their own way, so this annoying „competing" character, or negative advertising between the lines from the one over the other FW, has only a damaging quality. OPUS and HK for instance follow their own DEV philosophy, and I believe plurality in our world is a good thing. It’s not like comparing or competing „Apples with Oranges(Windows)" thing. The reason opposed to this is joy to create something for everyone. This is also why I criticized that, „don’t use this FW, wait for ours, it’s better" thing. This is not a RUN! People and FW users that read posts are no idiots, and can think for themselves - no need to bring them to one or the other side​:roll_eyes:
