Could anyone here translate the op1‘s delay settings lingo into a generally acceptable language?
what means ‚range‘ and ‚speed‘? Obviously not what you would expect…
speed is delay time
range changes like the max min of the range of the speed knob
feel like this is pretty self explanatory if u mess with it for a couple minutes
shrug
range also affects the size/fidelity of the delay buffer.
e.g. you can dial in the same delay time at different Range settings (with the right adjustment of Speed), but smaller Range will have a more lofi sound. (often useful)
This old topic should help get you closer to “sync’d” delays!
HTH,
