OP1 field and M8 are great friends except midi out over usb doesn't work
I’ve been playing with OP1F connected to Dirtywave m8 over USBC and it’s just magnificent. Audio comes in perfectly, midi send from M8 is great, sync is great, you can print audio from M8 to tape with a single cable then jam over it and I am actually in heaven.
The only small problem is that the OP1F doesn’t seem to be able to send midi to the M8, only receive from it.
That’s well known and discussed on the M8 discord (where the dev is incredibly responsive) and apparently it’s something odd about the OP1F and how it handles midi in USB host (I believe this because I’ve always found M8 to work great with everything, and tho I love the OP1F I’ve often found it to be picky and odd…).
So I’m just posting this here (1) in case someone else hits the same problem (you are not alone…) and (2) in the hope that TE engineers are watching and would like to fix it, because apart from that these two devices are a match made in heaven, tiny, glorious complementary workflow, and I’d love to be able to drive the M8 synths with the OP1F keyboard and sequencers!
Any update on this?
The latest OP-1 Field update fixes a lot of issues, and now both can send Midi/Audio to each other. Works quite nicely :smiley:
I have the og op1, what was wrong with the usb to midi?
@floris89 Can you elaborate on your M8 and OP-1 settings. I can’t get any response trying to trigger my OP-1 from M8 via USB. Not sure what I’m missing.
You probably want to set your OP-1 Field (this doesn’t work directly with the OG-1) to midi channel 9, this will allow you to send Midi from the OP-1 Field to the current track on the M8. When I want to sequence the OP-1 Field, I’ll generally set it to the midi channel associated with the track I am working on within the M8, just to keep my sanity of what/where I am sending midi notes to.
Hope that helps…
Thanks. Problem I’m having is getting the OP-1f to remain connected to the M8. When I connect them I can see the M8 as Connected in the Op-1 midi device list, but then after a couple seconds it disconnects. What cables are you using to bridge them?
Just using a regular USB-C to USB-C cable… I don’t think it is anything fancy… used both the TE provided cable and apple cable and both seem to work fine for me.
Any special tricks to doing this? I can get audio from the M8 into the OP-1F, but not from the OP-1F into the M8. Not sure what I’m doing wrong.
EDIT: turns out my OP-1 somehow wasn’t on the latest firmware. Just updated and now all works as expected: full 2-way audio and MIDI between M8 and OP-1.
can i check, you have it working fine with op1f and m8 model-02? i had the model-01 and it worked fine. but my m8 model-02 shows as connected for about a second after i plug it into op1f, then disconnects after about a second, every time.
are you using m8 model-01 or model-02? my model-01 works fine, but my model-02 has the same problem you’re having.
both on same m8 fw, 4.0.0
It works fine for me with OP-1F and Model:02… I’d check the cable first?
Odd, I’m a model 1.
Are you on the latest op-1f firmware? It is necessary to work for audio.
Also make sure you have a functional usb cable, some do not transfer data.
I had trouble connecting op1f to m8 over USBC. Just fyi it’s now mostly working. I still have the problem where, when I attach m8, the controls for it appear in op1f for a second then disappear. But what has changed is that the audio and midi now continue working between the two devices. Global midi changes on op1f (clock in out) affect m8. Nothing I did previously with factory resets and firmware and charging to full and different cables etc helped. But the last thing I did was an additional factory reset after again reinstalling the 157 fw. So it was either that, possibly in combination with other things, or it just happened to fix itself. Shrug, grr, hope it stays ok.
Will give reinstalling the fw a try. Thanks!
