OP1 Field - annoying reverb causing another reset…
Hi Guys,
Have yet another slight reverb going on all the time on my OP1 Field. Have turned off LFO, effects and all sequence controls.
Have also checked master dual controls and reduced, carried out the reset on synths and drums & done a new tape track last night but still getting the “reverb slightly.
Have had this is in the past 2-3 times so means a full reset (after a backup) but then that erases your sample packs so have to reinstall them.
I know I’m missing something simple somehow but can’t figure out where ?
Would appreciate any help cheers.
Mike
very odd. can you share a small snippet of this either as pure audio or video? thanks!
Don’t want to be annoying but definitely no reverb switched on the master FX, as opposed to the instrument FX?
Also don’t want to be annoying but is input set to microphone?
I want to be annoying, do you have your OP-1F plugged into a reverb pedal? :face_savoring_food:
Cheers for the advice.
All checked but nothing found so factory reset and reinstall sample packs.
Treated myself to Aurora/Rephazer pack to cheer myself up…..
As soon as reset finished then everything is back to normal and sounds crisp.
Одна из лент tape имеет характерный шум.
И при большой модуляции например эффект cwo создаёт собственный резонанс. Может у тебя все просто в настройках mono?
Насколько выкручен drive?
