Ok so I’m now curious to know how to go from op1 to korg volca using midi. Also if it’s possible to go from korg volca to op1 using midi. What exactly do I need to do this?? Camera connection kit? Are there several options?
I use the op-lab for this sort of thing, but that is mostly out of brand loyalty
If you want Volca to talk MIDI, you need a MIDI out mod.
For the other way around, I use ICM4+
what are you trying to achieve?
@dimi3 I’m trying to match tempos and record to tape simultaneously. Will any iconnectmidi do? Or does it have to be the 4?
The OG iconnectmidi midi will do. A computer or iPad/iPhone will also do. OPLab as well.
@dimi3 so I could go op1>macbook>volca>op1?
Oh right, you haven’t said “without a computer” : You may not need to buy anything if you have a computer + MIDI out gear
yes you could totally!
