I’m using latest OS with my OP1. I am using Logic X to midi clock sync the OP1 as slave, which syncs fine at the start but slowly the Tape loop drifts out over a period of time… my other hardware doesn’t do this when synced as slave from Logic (short loop say 4 bars)… is this a general problem with the OP1 when syncing it? It seems to be unusable as a slave with other hardware If i don’t manage to fix this it might have to go
This seems like quite a disappointing problem. Not been able to test, but it use to sync ok ,I think ,on old OS. Or maybe OP-1 was master ,can’t remember?have you tried driving logic with OP-1 as master?
Has anyone else had sync problems ?
yep, we’ve discussed this before. findings so far suggest that:
As stated here: https://operator-1.com/index.php?p=/discussion/comment/41071/#Comment_41071
As stated here: https://operator-1.com/index.php?p=/discussion/comment/41071/#Comment_41071You should ideally set MIDI Clock Type from Ableton Live to Pattern instead of Song for a more stable sync. I don't know if there is an equivalent in Logic
Yep - there is. It’s in “File | Project Settings | Synchronisation | MIDI” and here’s what the options look like:
also the OP1 processes SPP incorrectly at most tempo values. (been trying to resolve this with TE but alas, no luck)
Past few days have been a disaster trying to find workarounds with OP1, I’ve spent many hours - i’ve tried Logic and Ableton and with both there are issues with the clock timing of OP1… I’ve even tried program called MidiPipe to filter certain clock messages, or to send a song start message to give a little nudge… tried both Song and Pattern modes, Slave and Master… the sync is sloppy, it lags behind like an old fart
I got it working with Ableton for the most part, both in and out in Ableton midi preferences (for OP1) should have track/remote/sync enabled - this is strange as it suggests a loop sync from Ableton to OP1 and back
Gosh this is infuriating. I hadn’t realized how messed up the OP-1 was with MIDI! I mean you can’t even use the thing with the OP-Z! It just will NOT play in the same clock… The darn thing (when I press start) will confuse the OP-Z and both will be playing in a slightly different timing.
This is totally a major bummer.
