Op1f + ep - 40 midi
MIDI question, I’d like to use my OP1F with the EP-40, with the EP as the sequencer and the OP as a sound module. Two issues I’m running into, 1: even when I have the correct midi channel selected on one pad on the EP, and midi turned off on the other pads, the OP is still triggering samples on the other pads despite them being “OFF” 2. I would like to send play/stop messages as well but this aren’t sending to or from either device. Thanks!
System code 127 was the answer, by default the EP sends midi on the global midi channel so this needs to be turned off for my use case
