Title says it all. I’m planning on syncing multiple devices to the squarp but the opz seems to dislike the clock from the pyramid. At worst it freezes and at best it ignores all inputs. Midi is being sent from Midi A to the input of the oplab which is set to midi. Clock in is the only midi option selected for now. I’m new to the squarp environment so this is probably user error.
Is you OP-Lab making good connection in your OP-Z? The are known to have issues, works well if you put a little sliver of foam or something else thin between the input ports before installing the module and locking it in. This keeps pressure/wedges it in securely.
It is making good contact. It sends just fine and will recieve midi from midi out B, just not midi out A
