I have a new Ortho remote that I just can’t get to pair with my OB-4. OB-4 is running the latest firmware. The batteries on the Ortho Remote are fine, it enters pairing mode, but just won’t connect with the OB-4. I have been able to get it to pair to my iPhone so I know the bluetooth functionality of the remote is working. Any idea how to fix this?
make sure that the OB-4 has a blinking blue LED under bt, this indicates that the OB-4 is in pairing mode. if it isn’t blinking, if you hit input a few times to cycle back to bt, it should enter pairing mode again for about 30 seconds. if the ortho remote is also in pairing mode they should automatically connect
I had the same problem with the Ortho, I was pulling my hair out. The way I finally fixed it was to make sure the Bluetooth was turned on in the Ortho Play App so I paired it with the phone. It works perfectly now. Even when the OB4 has been turned completely off, when I turn it back on the Remote doesn’t even have to be paired again.
Hope you can get it going. I love it now that it works.
@jacobs As an update, I was able to get the remote working following @cnell58’s advice. Basically I had to put the remote in pairing mode, paired it with my PHONE with the Orthoplay app running, then the remote was able to control the OB-4 (but only in bluetooth mode at this stage. If I switched to line in or FM it would not control the volume). Then I unpaired the remote from my phone and now the remote seems to work the way it should.
To further clarify: I did all the pairing and unpairing of the ortho remote with my phone via my phone’s general bluetooth settings.
Posting this here in case anyone encounters a similar issue. It’s a strange workaround, but basically it seems that this is the only way to get the remote and OB-4 talking to each other, which seems to be via the Orthoplay app. Attempting to pair the remote with the OB-4 directly just didn’t want to work.
@FrankC interesting. i can’f figure out a technical explanation of why it works when you do it that way, it really shouldn’t make a difference. but if it works it works.
Hey there! I am having same issues with my Ortho and OB-4. Ortho serial # is R9CKI2EK. Can you send me firmware instructions for updating my Ortho? I can get it to pair with computer and iOS, but no functionality (no volume or play/pause control). I am unable to get the unit o pair at all with OB-4. I’ve replaced batteries, but still no luck.
Thanks, Matt
I’ve noticed sometimes I need to factory reset the OB-4 to connect with bluetooth, especially when I get a new iPhone. This happened more than once, generally when I upgrade my iPhone to a new model. Something about the protocol just seems to subtly change, and it absolutely will not pair until I reset the OB-4.
Which is not a big deal, just frustrating because one moment it’s working (with your old iPhone) and the next moment it’s not (with your new iPhone). I’m sure it’s an Apple thing, but I also can’t think of many bluetooth speakers I have this problem with?
you should not have to factory reset in that case, however, all bluetooth pairings can be cleared by holding down the play button while turning on the speaker, which may solve odd cases where bluetooth misbehaves. also, make sure you’re running the latest firmware version.
