This may be obvious but it just occurred to me now that Photomatic controls on track 16 can be controlled by external MIDI… I was tired of having only the 16 steps for Parameter locks on brightness, contrast, etc but with external control this isn’t longer a limitation. I MIDI CC-mapped outputs from a couple of virtual Befaco Rampage Modules in miRack/VCV rack to the Photomatic MIDI CCs and now enjoy infinite modulation complexity for my visuals, woohoo!
Great to know! Ty for the insight!
Would you mind sharing a miRack patch to try out? ![]()
Here you go:
You just need to select the op-z as a midi device in the two midi modules. The one on the top left just controls the clock with the op-z play/stop buttons. Btw, If anyone knows how to wire the op-z midi clock bpm to miRack without another host app, let me know…
Rampage outs range from 0 to 10 volts, this will be converted to midi values 0-127, then in the op-z app to 0-100 parameter value… somewhere along this path it gets a bit jaggy and sometimes jumps values. I have yet to try this setup in VCV rack…
@vantablack Did that patch work for you?
btw, the same works for the Light track on MIDI Channel 15, wohoo!
Wow thank you! I’ll try it out and reply
