Please can we have a normal decay envelope on drum sample kits?
Haha AARGH please can we have a normal decay envelope on drum sample kits?
I am totally into the creative limitations but this is just a simple missing thing, it creates huge clicks otherwise, especially when you’re using more interesting one shot samples in there!
Yeah this is definitely needed. This should have been one of the first things TE changed when they released the OP-1 Field.
PLEASE TE ADD THIS - This can be added in the place of the existing ‘transient shaper’ on #2 in the drum interface… perhaps the user can choose to switch between them when you press shift + 2 and select ‘shaper’ or ‘envelope’
exactly. shift to access attack and delay.
I sent a detailed feature request to TE about this about 6 months ago. I agree this is the single biggest problem with the Field. If it was possible to chop samples without clicks the Field would instantly become one of the best devices for sample based music, period.
Wait TE never addressed the clicks all the way back from the OG OP-1? Or am I thinking of the tape loops?
Did the same a year or 2 ago - really hoping it’ll happen one day
Synth sampler doesn’t have clicks like that but the drum sampler does when using chops. It’s like there is no zero crossing between samples when they choke each other. So frustrating
This would be nice. Does anyone here actually use the weird drum envelope?
Nobody in history has ever used the weird drum envelope.
I used it on accident one time.
for the love of god, teenage engineering. How hard can it be to do this?
I would moreover suggest a fix for an issue in the same line. In synth mode, if you set a loop close to the end of the sample and keep a long decay in it’s enveloppe, then you’ll get an annoying click. Obviously, the fix would be to calculate the remaining time in the sample after the loop end and add a sufficient number of loops so that the total time would fit the time required to finalize the decay. It should take a few lines of code to calculate the proper duration, then create a temporary copy into memory to play the sample in a good manner when the key is released.
I’m probably in the minority that loves the drum transient shaper on the OP-1F, but I also strongly agree that having an alternative regular AD or even ADSR would be super nice to choose between or have as a secondary VCA shaper in addition to what we have now.
it’s not really an envelope, at least not an ADSR, it’s more like a transient shaper.
