Hello;
For me it’s the same. I ve the PO 20, 24 and 28 … and the PO 24 is like half the volume of the other two. No idea whether it is supposed to be like this, but I know what you are talking about.
have a good evening.
Hi, I have PO 14, 24, 28. PO 28 Robot has half of the volume compared to Arcade and Sub. Should I return it back?
Some of the sounds of my PO-28 Robot also makes clicks on the beginnings and noise at the ends. It’s easy to here on the sound 4 and 12 in solo mode. Is it normal?
@Boraboras Can you post an audio recording?
Yeah, my PO-24 is pretty low in volume too.
So here is the response from TE
Hello,
Thanks for your email. The output is lower on all of the 20-series of pocket operators.
We made this on purpose since the 10-series had distortion from volume BPM+13 and upwards.
So please try and put the PO-16 and PO-32 on volume 12. BPM+12 and PO-24 on BPM+16 I hope this will work better.
haha yeah, PO10 series are really loud~~
play it loud O(∩_∩)O
I found a YT video a few months back showing a way to hook them up together to mitigate the volume differences. Here’s a wallpaper I made that shows all of them hooked up with sync and volume settings. If you’re only using a few of them, try the same order and volume but minus the other ones: http://imgur.com/TTRYeOk
Thanks for all the answers!
