I just got my hands on the PO-32 and I’m not really sure how the Microtonic VST works when transfering sounds, I’m able to edit the first 8 sounds and send them, but is it possible to transfer to slot no# 9-16, or are you supposed to make a new kit, and manually transfer the remaining sounds?
On the Microtonic VST, when you click the TE logo and go to the “sounds+pattern” tab, there is a dropdown next to “transfer sounds to” and it has 1-8 and 9-16.
@jimboeh, there are just 8 sounds to create in microtonic Vst at the time. You need to create a new preset with 8 other sounds in the microtonic vst, to send them to 9-16.
Also, using the ‘program’ function in Microtonic, you can have multiple kits in 1 Microtonic save file, simply load up to 16 kits into the 16 program slots and then export as a ‘.fxb’ file. This stores the entire Microtonic software state AND includes all morphs for each kit!
You still have to specify the slots for PO32 transfer but I find it much more convenient than saving 2 separate Microtonic kits for each full PO32 kit.
