Hi everyone,
Recently I bought a used PO-33 with the lock pad broken off. Soldering a connection between the two pads did not seem to have any effect. I tried soldering and de-soldering several times (just in case) and confirmed a connection with a multimeter but I cannot get the PO to reset to factory settings.
Has anyone experienced a behaviour like this? Is there still hope, and what could be the problem?
Thank you
so it still saying “noP” when u go to sample?
longshot but u could try factory reset see if it jumpstarts it
otherwise if u have the two pads connected
and it still not letting u sample
it might mean that the connection is broken somewhere between the pad and the chip itself
which is not as easy of a thing to suss out
it never resets properly and I only get the “noP” message when trying to record something. I soldered the reset pads again with no success.
Unfortunately, the previous owner did not put very much effort into preparing proper samples before breaking off the lock pad
))) ꏿwꏿ (((
