Hey All,
That’s strange, from my experience they are able to have a pretty stable synchronization between them
I wonder, how do you sync Ableton as slave to the PO units? I have done it the other way around by sampling the click from the PO and it works fine
I think that’s the thing, I’m not doing any kind of syncing with Ableton, I am just doing raw input. But you wouldn’t think it would matter, since it’s just raw audio right? Especially since I am just playing freestyle from the robot, I’m not hitting play and letting a sequence cycle through.
if you’re not syncing the po’s to ableton at all, and you’re noticing a lag in the audio response, like hitting a button, then after sometime you are hearing the sound, definitely sounds like an audio issue. does your macbook have a built in audio input? does the same thing happen if u use that instead? or if u have another audio interface u try or a friends u could borrow real quick?
Okay that makes sense. Unfortunately I don’t have a built-in input on my macbook pro (they eliminated it a model or two back), I do have a very nice Focusrite interface hooked up to another computer in the house I should test with, so I’ll do that.
That might be simply the latency settings, you can easily reduce its value in Preferences/Latency/Buffer Size
