Hello there ! It seems that PO clock out doesn’t work on my Oplab when I receive midi in… Is it normal or is it another bug of Oplab ?
Thanks all
I have the same issue
I had to make sure if i was using the switches it has when the unit is off.
Then i turn it back on and then it seems like it works.
If i switch the switches on the OPLab Z with the OP_Z on there is problems.
Just in my case.
