PO for eurorack kit
#1
All you pocket operators / eurorackers may find this interesting:
https://www.thonk.co.uk/shop/lpzw-po-series-euro-adaptor-kit/
#2
no actual CV control over anything? what is the point then?
#3
For one of the following reasons I guess:
• hold a Pocket Operator in your Eurorack Case
• supply power to the PO from Euro bus-power
• route the I/O 3.5mm jacks to the front
• divide incoming 16th-note clock to a 8th-note clock used by the PO
• safeguard against higher trigger voltages than the PO accepts
• amplify the output signal times 2
It’s only £35.
Without diving in and reprogramming the flash firmware I don’t think CV control over anything else would happen.
#4
good points. just not sure i’d want to wire my PO up permanently or have to get 2 in order to keep one portable/free.
also not true. u can easily wire each button up to provide gate trigger
as well as CV control over the knobs. no reprogramming the firmware.
its all just voltages anyway
#5
Ah ok, that makes sense. The knobs work with button combinations so I assume you’d have to mash the buttons, which could be pretty cool, especially if you hooked the buttons up to arcade buttons.
#6
well if u hooked up the buttons to gate triggers, u could do all this hands free.
its a lot of work and the solder points are relatively small.
i wouldn’t wanna do this myself, but its definitely possible.
