Hi there,
Im trying to record some samples onto my po -33 but its not working.
if i press record down with a number it doesnt record a sample, or even show a level meter for the incoming signal. the top right of the screen says ‘noP’ when i press record with a number.
anyone have any ideas?
cheers!
noP means that the lock tab has been enabled somehow
which prevents sampling
if u haven’t physically removed hte lock tab then i would say
prolly the trace has been broken and u need to solder the two pads on the back near the tab together should fix it
if the trace is still intact and its still saying ‘noP’ then there might be something deeper that is not working properly
