hi.
I may be mistaken, but I don’t think you can send a start message to the POs, only clock. So even when they’re tempo synced, you’ll need to start patterns manually by pressing play on the units. I think TE’s stereo out sync is clever, but I found it much easier to use either a Volca sync out or Korg’s free iOS sync app as a master clock. Use a headphone splitter, you can even route headphone splitter -> headphone splitter or use a belkin rockstar to sync all three POs from a single sync source.
i got a volca i can hook up, thanks for the info.
Hi I use a 3.5 to 3.5 mono coupler from maplin than a 3.5 mono to stereo adapter not proper stereo but overcome mono output
http://www.maplin.co.uk/p/35mm-mono-plug-to-35mm-stereo-socket-adapter-fk14q
http://www.maplin.co.uk/p/35mm-metal-mono-coupler-l33az
Happy to help! Love the Pocket Operators. Just have to make sure they’re all on the correct sync mode when syncing from an a single external source- should be SY2.
i haven’t tested this yet, but i figure you can send one of the pocket operators ouput to a mixer (using a 3mm stereo to phono l-r pair cable) then use fx sends to feed each of the other pocket operators the sync pulse(left channel) from that device. each pocket operator could have separate stereo output to mixer. (is stereo output really necessary with these devices?) the first PO would be left=pulse/right=mono audio out (sy1) and the other two would be sync in/stereo out (sy4).
OR
send some external signal to all 3 devices via aux sends on a mixer and have all 3 devices stereo out back to mixer. (sy4 on all 3 devices and external clock source)
i love the idea of using the aux out from a mixer to sync the operators but i’m trying to make an even more compact setup.
@trojan Left/right output signals are identical.
not in sync modes that send sync pulse on left channel, but yes, no need to record each device in stereo then.
https://www.youtube.com/watch?v=_jY0aOYAp3g
that looks similar to what i could get working , though might go for small mixer with fx sends on each channel for output to my kp2s .
Hey @re5etuk
I’ve got some ideas for some cases in the works. Was gonna try to sync the three internally, wiring 2 mono sync in and out jacks and have a seperate audio out for each (mono). I just got my second PO today. about to experiment.
Finally all my pocket operators together!!! They are mixed individually, thanks to awesome @darenager passive mixer. Unfortunately, the sync signal is going too low through the mixer, so PO`s are synced from each one to the other one (not via the second mixer/splitter)… The output audio signal is also very low for headphones, so it is necessary to use some preamp…
@veverkoid that is a thing of beauty!
@ververkoid Looking good!
Thanks!!! There is a few punk moments (especially in wires), but it works for now ![]()
