Hi!
I have the PO35 and I’m thinking of getting the PO33 too.
Anyone tried sampling with external mic?
Which mic you use?
Is it better quality or not noticeable?
Thanks
Hi!
I don’t think you will get much of an increase in quality and you’d need a pre amp as the input is line level, the built in mic seems ok to me, but the sampling is only 8 bit on the KO.
Thats surprising that its only 8-bit, how does it sound though? Does it have mojo like the Volca Sample?
Ok, thank you for the info
Hi!I have the PO35 and I'm thinking of getting the PO33 too.Anyone tried sampling with external mic?Which mic you use?Is it better quality or not noticeable?Thanks
The external mic is alright. I only used it on some percussion but this weekend I’ll play around with tones and stuff. farts.
