Sure, there’s other ways to sync up you POs, but the Pocket Integrator makes it this easy.
One thing that helps: when you tap the Integrator 8 times or less, tempo will be rounded to the nearest even BPM value. This really helps if you’re syncing up with any gear that sets tempo by BPM … including other Pocket Operators! On the other hand, if you keep tapping, the time measurement just gets more and more accurate.
