- OP-1 (rechargable)
- iPad Mini 2 (rechargable)
- Bose Soundlink Mini (rechargeable)
I don’t know if you’re set on a hardware solution, but another idea is to run AUM as a mixer on your iPad.
I use this method too.
One option is art splitmix4
Hmm, or cue out won’t work I think. I have to check.
maker hart just mixer. super small (PO size). runs on 2 AAA battery or micro usb jack
The Bastl Dude could work as well. It has 5 inputs, but they’re mono.
ah should really read the posts better…
Thanks all.
Yeah, splitmix won’t work, since there’s no independent monitoring. But if you’re fine with mono, there’s a lot of options. I don’t think Bastl Dude has a cue out though. This one has, for example: http://en.uraltone.com/uraltone-tube-sounding-micro-mixer-rakennussarja-15839.html When using as a mono mixer, the pan pots are actualy the cue/master balance pots. It can be powered off a 9v battery. My friend has one of these, they are pretty neat. Also, tubes. =)
Yeah, splitmix won't work, since there's no independent monitoring. But if you're fine with mono, there's a lot of options. I don't think Bastl Dude has a cue out though. This one has, for example: http://en.uraltone.com/uraltone-tube-sounding-micro-mixer-rakennussarja-15839.html When using as a mono mixer, the pan pots are actualy the cue/master balance pots. It can be powered off a 9v battery. My friend has one of these, they are pretty neat. Also, tubes. =)Oh, and like @rumorazzi, I route OP-1 audio through AUM/iPad all the time too. If you already have an iPad audio interface, that's definitely the most compact solution.
I have an interface, and I have AUM. I’ll feel it out. Thanks.
Yeah, splitmix won't work, since there's no independent monitoring. But if you're fine with mono, there's a lot of options. I don't think Bastl Dude has a cue out though. This one has, for example: http://en.uraltone.com/uraltone-tube-sounding-micro-mixer-rakennussarja-15839.html When using as a mono mixer, the pan pots are actualy the cue/master balance pots. It can be powered off a 9v battery. My friend has one of these, they are pretty neat. Also, tubes. =)Oh, and like @rumorazzi, I route OP-1 audio through AUM/iPad all the time too. If you already have an iPad audio interface, that's definitely the most compact solution.I have an interface, and I have AUM. I’ll feel it out. Thanks.
You could use a fader box for have physical controls over AUM’s channels.
When I need it I use a nanokontrol studio, it’s bluetooth and battery operated.
monitoring in AUM tip:
use a bus send pre fader, it will send even if the channel is muted. receive on this bus on another channel, routed to your monitoring outputs.
I use a Nady MM-242 it runs off a 9 volt and has 4 stereo channels. The bad thing is that if you plug it in it hums a lot. Also it does not have headphone out so it actually does not meet your needs.
