Pressing the encoder is not deterministic, most of the time it doesn’t change the state or it does it a few times in a row.
Today I figured that if I press the encoder and - while having it pressed - i use slight of force to move it to the bottom - then I switches the state like crazy. I think it’s a bit “loose”.
As you can see on the video orche works just fine.
Had anyone similar problem?
Is it simple to fix?.. If at all?
