Problem then sampling, the waveform is not in right position
I have tried to sample both with mic and resampler, but get problem the position of the waveform is wrong. ex a sample drum and snare, the snare start pos is between those samples, then it is only zero.
Have anyone else the same problem ?
I’m not sure if I’m understanding your question so please correct me if I don’t answer your question :slight_smile:
It sounds like you’re sampling/resampling but the sample doesn’t start playing where you expect. If that’s the case, could it be a threshold issue? In Sampler mode, the fourth knob/encoder sets the threshold. If it’s at 0, it will begin recording immediately and your sample will have some silence at first. If it’s very high, it won’t start recording until the sound has already started playing, and your sample will start partway through the sound.
One more thought: for drum tracks, the amplitude envelope (M2) controls the sample start point, so it’s worth checking the envelope itself as well as anything that could modify that parameter (LFO, Mod settings).
That was a more dense reply than I intended to send so please let me know if you have questions!
Thanks , I will check and see if this was the problem :slight_smile:
