problems moving patches to OP1 - please help
Hi all
I have a problem which is probably a noob question with a really simple solution that i am just overlooking:
I have found the “new” patches in the custom firmware tread and have successfully moved the Synth patches to a “iter” folder.
But the drum patch with “filter” effect won’t copy properly, so some help trouble shooting would be much appreciated.
what i do is:
SHIFT+COM , then “3” disk mode and then connect the USB cable
I open the finder and create a subfolder in the “drum” folder on the OP1 labelled “filter” and copy the patch “drum_filter_patch.aif” into the folder.
I now choose to safely remove hardware, and once windows says i’m good to go i pull the cable… then nothing happens, the OP1 is stuck in COM/DISK mode. and when i restart then the copied patch is not loaded.
Any help would be appreciated
Very best Johan
Not sure but I think you’re limited to 10 characters
Thanks a lot bc99
Reducing the title to dr_filter solved it!
