Puzzled by the battery charge indicator
Hi All,
I’m a new lucky owner of an OP-1 and I am a bit puzzled by the battery indicator. After an entire night charging - using a quality mains to USB charger I use regularly for my Samsung S8 and Nintendo Switch - it just gives me 4 out of 5 leds (when I click the “help” button). Is that normal? Am I missing something? Thanks!
The battery meter can be a bit off over time. You can recalibrate it by draining the battery until the screen goes dark. Then charge it with the power switch set to ON, at least 6-7h, using a dedicated charger. This is the official recalibration procedure as mentioned in the manual.
Another trick (not invented by me, too lazy to look up the original comment) that might work is charging your OP-1 while off. The power on for a bit and charge while on. This usually works for me as well. I’m reluctant to drain the battery completely as it is not healthy for it.
