For those with the op-z, is it possible to edit the synth engines using the app or are you limited to the 2 parameters in the app too? Also, for the synth engines that are the same as the op-1, can you transfer presets over from the op-1? Finally, given the physical 16 step limit, how easy is it to come up with patterns that are more complex than 1 bar? (I understand you can have more steps but then you can’t access them from the sequencer)
You can with the APP but you can only move one parameter at a time.
You cannot just grab a bunch of things and move all of them.
The engines are not the same. But you can take a 6 second MONO 44.1 file and
use it as a synth engine in OPZ, and the KITS are the same from the OP1 Drum App.
You can elongate steps by using i+UP ARROW + a number to divide the steps
to longer patterns.
„You can elongate steps by using i+UP ARROW + a number to divide the steps
to longer patterns.“
Can‘t follow you - what do you mean?
Button combination of track,shift and a black key to multiply the track length
Yeah right, know the combination but wasn’t sure:)
