I just read the TE manual and I have some unanswered questions I hope some of the vets can help please!
- drum sample play mode - there is “play to end” , is there “note-on” like on mpc’s? I want the sample section to stop playing when I unpress the key.
- can I load 8 different 12sec drum samplers into keys 1-8? basically giving me 96sec?
- when lifting from tape into drum sampler, how can you ensure you get a 12sec cut?
- in situation 3 above, if I increase the tape speed can I lift more of the music into the drum sampler and then pitch it down in the sampler to get more than 12 sec sample time? This is an old SP1200 trick. Or is the 12sec limit fixed to the normal speed of the tape.
- can I undo only the overdubbed part on a section of tape and keep the original audio before the overdub?
thanks for any help yall!
