Hi folks.
Budget small
Hi folks.
Budget small
Hi Peeter, the main thing to look for sampling is whether the turntable has a “line” output or only a “phono” output. The signal from the phono output won’t sound right when you sample it, so you’ll need a separate “phono preamp” to convert it. Many newer turntables have a phono preamp built in, and so they’re ready to connect directly. If you aren’t too concerned with audio quality, anything with a line output will do.
For a budget pick I suggest the LP60 from Audio-Technica:
https://www.amazon.com/dp/B002GYTPAE
It’s ready to connect to the OP-1 mic input out of the box. It has a switchable line/phono output and an 3.5mm jack adapter.
If you have a little more to spend, and you want to use the turntable for listening as well as sampling, consider stepping up to the LP120, which has a better drive mechanism and a fully adjustable tone arm.
https://www.amazon.com/Audio-Technica-AT-LP120-USB-Direct-Drive-Professional-Turntable/dp/B002S1CJ2Q/
PS. I have no personal experience with the LP60. I am mainly recommending it cause a) the LP120 is really good and b) it’s cheaper while still meeting your needs for sampling.
hth!
Cheers macfergus. Im onto it now. Do the usb to mic input cables usually come included? I guess they arent.
Normally you’d only use the USB output for sampling to a computer. If you want to sample directly on an OP-1 or other hardware, you’d use the RCA output.
Most turntables won’t include cable you need, although the LP60 does. If you pick up a different turntable, you’ll probably need an adapter like this one:
https://www.amazon.com/RiteAV-Stereo-Female-Adapter-Y-Cable/dp/B0018MI5F6/
They are easy to find and shouldn’t cost much more than about US$5.
Thanks. Shows how little i know! Good thing im in the right place to ask. Thanks!!
