how should I do that…
anyone?
anyone?
There’s a config file in config\general.json that has a few options all defaulted to (false) or off…
backlit_keys : keeps the led’s on all the keys except the 16 sequencing keys which operate as normal.
disable_microphone_mode : stops tipping the unit from activating the mic
disable_start_sound : disables the startup noise
disable_track_previews : disables the sample note that is played when you select whatever track.
have overseen this!
Midi Echo to ON and same channel on tracks gives you a synced recording of whatever tracks you want.
you can use the 4 synth tracks as a 4 voice poly…
