I was wondering if it’s possible to record a song from the XY using a phone. My idea is to connect the device via USB-C and use a mini-jack to listen through headphones.
Could you let me know if this setup is feasible? Also, would I need to configure any specific settings on the XY for it to work?
Yes is possible! I’ve tried with my ipad (USB C) and with an iphone 15 and work perfectly. Doesn’t work with iphone12 and camera dock (original), i receive a pop up message on the iphone12 that say the device require too much energy
It is possible, however for me using Android (Google Pixel 7a) it becomes choppy, as if midi data is causing stop start. I played around with settings and couldn’t rectify it (albeit not thoroughly).
I even had the same issue through PC. I feel they may need to fix something. I have already submitted a ticket on TE website.
I tried but it doesn’t work with a Google Pixel 9. should I use a specific software or setting within the op xy?
I go not music recording on the phone coming from the op-xy
does it work for you with iPhone 16 Pro when using the camera app? As in filming with the OPXY as a sound source via USBC. I get choppy audio, clicks and pops.
