Ok so I am getting into resampling 4 tape tracks down to 1, but want to know if there’s a way I am missing as each way I am using now has ‘issues’.
Hey @MirEko this might sound a little dumb, but you just need to hit the buttons at the same time. If you nail it, it will be perfect timing. I always have a “test patch”, where I will copy my tape track across to a “blank” piece of the tape, and practice on that part to get it right first. If you nail the timing, you can bounce back and forth from tape to album and back again in pretty much perfect time.
use ear and bounce down right on the tape
As @docshermsticks said most of the time I resample 3 down to one:
- Turn off all effects on the „master bus“
- Set record source to ear symbol
- Set record volume to max
- Hit the mic button so you record from the ear:)
- Select the empty track to resample from the other 3
However sometimes its a bit quiter then the original, in this case I fiddle with eqiing till it works out.
Ah and you can do a loudness a to b comparsion quickly by switching between holding down the button for the original 3 and the other 1.
As @docshermsticks said most of the time I resample 3 down to one: 1) Turn off all effects on the „master bus“ 2) Set record source to ear symbol 3) Set record volume to max 4) Hit the mic button so you record from the ear:) 5) Select the empty track to resample from the other 3However sometimes its a bit quiter then the original, in this case I fiddle with eqiing till it works out.
This is good but I will always be going 4 to 1. And gain is the big issue I keep running into. It looks like rec to album is the best way to do it
Hey @MirEko this might sound a little dumb, but you just need to hit the buttons at the same time. If you nail it, it will be perfect timing. I always have a "test patch", where I will copy my tape track across to a "blank" piece of the tape, and practice on that part to get it right first. If you nail the timing, you can bounce back and forth from tape to album and back again in pretty much perfect time.That said, screwing it up is really the sound of the OP1 I think :D
Yup
it’s not too hard but, maybe if I turn on the metronome
Maybe that’s the problem… I’m not sure, but you must record 3 to 1, otherwise you record 1 on top of 1 again.
This is good but I will always be going 4 to 1. And gain is the big issue I keep running into. It looks like rec to album is the best way to do itMaybe that’s the problem… I’m not sure, but you must record 3 to 1, otherwise you record 1 on top of 1 again.
This is why I use the album, record 4 tracks to the album, record album back to empty tape.
or if you had a track that plays at 99 volume, you could overdub the other 3 on it in pretty decent sync:1. mute track to overdub on. the contents will mix with the other active tracks2. turn off all mixer/master effects3. set input to ear, input gain to 0.0, track input level to max4. turn ear on5. record on muted track6. mute the other 3 tracks, unmute overdubbed track7. turn effects back on8. check recording is what you wanted and lift/delete the other tracks
This might be what I’ve been looking for! At work right now but going to try this out when home, Thanks!!
