I max out EQ on bass, mid, treble (usually have that by default)
Remove master fx (unless I want to record that too)
Zero Drive
Arm my white ear
However, I generally test the recording level by doing a few seconds of white ear recording and then play back to see if I’ve got the level right before doing the full merge. I certainly don’t have it on 100%, that often distorts it for me. More like 50% (possibly because I max out EQ?).
One thing though - you mentioned you got the same panning in your result. The individual tracks are mono, it’s just the master that’s stereo, so after merging, I’d have thought there’d be no stereo.
Thanks, @yoof
I didn’t know about maxing EQ’s trick. And I’ll check panning carefully later again.
You said, that you recording at 50%, so how did you get same recording level without master distortion? Did you experienced problems with the background noise?
Yes, with the red vertical slider at around 50% (I defo have to play with that a few times to get it just right), I seem to be able to record it as near on exactly how the multiple tracks sound in my master before merging. No background noise and no distortion. So, my recipe is basically max EQ, no drive, no fx and do a few attempts using different levels of the red slider to find the right level.
