Hi guys, i wondered if someone could offer some advice / tips n tricks on how to achieve riser sounds, sweeps etc to build transitions??
easy ones…
The tricks above are great. I also like to record things in reverse with delay or CWO to get nice swells when everything is played forward. Go to the beat marker where the ‘drop’ is, then hold the record button, the backwards ‘R’ button, and hit the notes you want or trigger your sequence. Just make sure to keep holding the R button or else the tape will play forwards. Lift and drop your work beforehand in case you are not happy with your first attempt.
hot tip @lymtronics
You can also use the digital synth set just to output like a broad noise, slow attack with the nitro filter and element LFO set to envelope - white noise filter sweep riser
high portamento (shift + 2) & arrow keys as you play a note can help raise or drop the pitch of a sound dramatically. having a bit of Release in your ASDR envelope will help too.
The tricks above are great. I also like to record things in reverse with delay or CWO to get nice swells when everything is played forward. Go to the beat marker where the 'drop' is, then hold the record button, the backwards 'R' button, and hit the notes you want or trigger your sequence. Just make sure to keep holding the R button or else the tape will play forwards. Lift and drop your work beforehand in case you are not happy with your first attempt.
holy shit why have i never tried this.
G-element!
Awesome tip @lymtronics - I also started using the Value LFO - source set to Envelope, destination to white speaker/ green for pitch - then adjust atttack on the envelope to affect the length of the rise.
But this Reverse trick is on another level!
Awesome tip @lymtronics - I also started using the Value LFO - source set to Envelope, destination to white speaker/ green for pitch - then adjust atttack on the envelope to affect the length of the rise. But this Reverse trick is on another level!
*element LFO
Not being a D, just correcting typo in case noobs are confused.
My bad! ?
