Hello
Hope everybody’s well and safe (and of course enjoying creating sounds).
This is my first post on the forum.
I just got an OP-1 and I would like to ¨connect¨ it with my Roland Ju-06a.
My goal is to record sound of my Roland onto the tape of the OP-1.
I’m not talking about sampling. I would for example like to record a sequence or
some chords on my Roland to the tape of the Op-1.
Is a simple Midi cable the answer to this?
I’m very new to synths and electronic music in general so I don’t have a lot of knowledge about hardware, software, cables, etc.
Thanks for your help!
to record sound u need an 3.5mm audio cable from the output of hte JU to the input of the OP1
if u want to control the JU with the OP1 like play the OP1 keyboard or sequencer(s) and have that trigger the JU, then u need a USB MIDI HOST & a MIDI cable
Hmm somehow I can’t make it work. What am I missing?
did u select line in the input selection screen? shift + mic
then did u enable the external audio by pressing mic again on the tape screen?
https://teenage.engineering/guides/op-1/recording-external-sources
No I did not to this😅
Got it working now.
Thanks again for your help!
@docshermsticks says “need a USB MIDI HOST & a MIDI cable”. Or, if you have an iOS device, you should be able to sync in a relatively cheap and compact environment by connecting both the OP-1 and the boutique.
