The Korg Volca Sample is gonna arrive here in a couple of weeks. Now i want to buy a small passive stereo mixer to connect the OP-1, the volca sample and keys and my monotribe.
I am thinking of buying the Rolls MX 41b. Does anyone here have experience with this little mixer?
Not used that particular one, but passive mixers are generally all the same, you lose a fair bit of gain which gets worse the more devices you have connected, often though it is not a problem, for example if recording you can make up the gain on the recorders input. Passive mixers add no noise but can suffer from a bit of crosstalk if the connected devices have different output impedances, but in the case of the 3 devices listed you should be ok.
Thanks for the info. That might become a problem if i wanted to attach other things? I also have a mopho keys, a blofeld, a Tempest and an MS-20. I probably won't use it for those as i also have a Mackie mixer. It's purely for jamming with small devices in the living room...
@Kites
Thanks for telling about this one. It looks very nice, shame about the noise though. I was hoping to avoid an adapter..
Like a lot of other Volca users I feed all my portable toys into my Belkin Rockstar. Works like a charm. Great for use in the Microbrute patchbay too.
What I have never found is a little portable mixer, passive or otherwise that can pan. That is all the Belkin lacks. Sure, gain is sometimes an issue but you can’t have it all!
I was looking for something just above the Rockstar, e.g. with pan, active.
But in the end, I am now looking for a full mixer, with FX and the ability to record straight to a USB key or something, as well as being a USB audio interface. Still trying to avoid computer as much as possible.
@johnl w/o getting too expensive or crazy, i think this behringer UFX1204 might fit your bill. not too many "budget" mixers out there w/ ability to record straight to USB thumb drive.
