Sampler Start/End Position Full Modulation?
When modulating the start position on sampler using a LFO, why can’t the start/end position be modulated to the full length of the sample?
Turning up the LFO amount to 100 only modulates the start position ~25% of the entire length, my thinking is that it would modulate the entire range like other parameters.
you might need to make sure your markers on the sample span the entire length too. i know on the field there are 4 markers. the true start/end, and then the loop start/end. maybe try toggling these 4 to make sure there isn’t some placement that would enable the full sweep. just an idea.
yea tried moving all markers around, start/end seem to modulate without respect for loop start/end position, also modulating loop start/end seems to modulate larger ranges but still not able to be the entire sample length
Hi! I have the same issue, have you found a workaround?
I have tried both external midi and internal and cannot get the start time to modulate in full. I often use a step sequencer to modulate start time giving an auto slice kinda feel and would love to find a work around. This seems like a bug to me.
