Samples on OP1 Field
Hi thanks for letting me on the group , is not possible to record samples into the OP1 Field and then put a different sample on each key like you would on an MPC etc . Thanks in advance
You can record multiple samples onto the tape and then join those takes to make a single take (you may need to cut/move takes first). And then if the length of that newly constructed single take is no more than 20s then you can lift it and drop into a drum sampler where you can create slices for keys.
Cheers man i’ll give it a try
just adding a couple other ways to get there
u can sample the whole thing directly into the drum sampler and then chop it up
u can also roll your own using hte drum utility
load up each sound onto each key and then export the file and load up into your op1
