Is it possible for the fx to be wet only? Been trying to use it as a send and return fx for my mixer but need to lose the dry signal coming back into the return.
The pressure pad is essentially the wet/dry control. No pressure is full dry, pressing down is full wet, can lock at one level or record a “loop” of either the pressure pad or the rocker.
To lock at some value, press the pad at a desired level, and tap the [Select] button once.
To record a parameter, hold [Select] while interacting with the parameter and release both when done.
To disengage, interact with the previously locked parameter.
Ah yes good point thanks.
