Sooo I was thinking it would be nice to lock patterns sometimes into the PO-3X series but then reverse it on the fly. Obvious solution: solder a switch to the lock pads, instead of just soldering them together.
I thought of trying it, should work fine, the tricky part is finding a suitable switch.
https://www.google.com/search?q=MSK-12C02&source=lnms&tbm=isch&sa=X&ved=0ahUKEwilldvMj5XZAhWe8oMKHaM4CrQQ_AUIDCgD&biw=2048&bih=1022
i dont have one fo the newer PO’s so i cant comment on pad spacing. but these are nice and small.
whats the distance between the pads? is it ~2.54mm?
Beyond the dimensions to fit the space, I think it would be a bonus if the switch “handle” would be low profile so it doesn’t accidentally get switched on and off.
<span style=“font-family: “lucida grande”, “Lucida Sans Unicode”, tahoma, sans-serif; font-size: 12px;”>Alternatively, a tiny rotary switch that you could turn on or off with a screwdriver.
i dont have one fo the newer PO's so i cant comment on pad spacing. but these are nice and small.
Maybe if one soldered this on so that the switch was facing inward, towards the screen, then it would be protected enough while still being accessible enough
Sadly not, looks like 1.5-2mm pitch.
What about some pin headers and a jumper cap?
Again, it’ll depend on finding some with the right spacing.
dang…well that makes it a bit more challenging.
I keep thinking it might be cool to add CV for the knobs, it would be pretty simple although I’m not yet convinced how useful it would be, given that a button needs to be held, but then I thought about adding a gate control, then I though about a gate control for each button, then I thought that sounds like too much work, so then I turned my brain off
ayyyy…lock switch achievement…unlocked.
Now that’s what I call a surgery!
wasn’t too bad tbh. whenever i do mods, i am always mentally as prepared as one can be to lose the device tho.
Can anyone with first hand experience confirm that exactly what is frozen when the lock tab is broken? You cannot record new samples or new patterns, correct? But can you modify knob parameters until the batteries are removed? Does soldering the lock leads allow you to do a factory reset and return the original KO! sounds? (pattern + write + insert batteries)
thanks! yea i kinda just did it for fun but its actually really useful.
nice to lock samples when u put it in your pocket/bag
or just if u are vibin’ heavy w/ it and u don’t want to accidentally erase a sound
(has happened to me once or twice mashing buttons a lil too fast)
