Solution for OP-1 Original Disk Not Detected on Windows 10 Pro N
Hi everyone,
I wanted to share a solution to an issue I encountered with my OP-1 Original by Teenage Engineering on Windows 10 Pro N. Windows wasn’t detecting the OP-1’s internal disk, which prevented me from transferring files. After investigating, I found that the issue was due to the Windows 10 Pro N version.
Switching to Windows 10 Pro resolved the issue completely, as Windows 10 Pro N lacks certain media components that likely caused the incompatibility.
I wonder if it would be possible for Teenage Engineering to consider releasing a firmware update to address this compatibility issue. This might be helpful for many users experiencing the same problem, especially for those who find it inconvenient or difficult to reinstall Windows 10 Pro.
I’m sharing this information in case it might help someone else. Switching from Windows 10 Pro N to Windows 10 Pro should allow the OP-1’s disk to be detected without issues.
For more details, you can check the post I shared on the HP forum: HP Forum Post
I wish you a perfect day
