Hi there op-people! I’m a new happy owner of this toy and would like to share some sounds that I was lacking in stock presets.
Some Rhodes (Clean and Chorused), Wurlitzer, Moog Bass and Hammond with rotary speaker assigned to G-sensor.
Please let me know if I’ve done everything right in exporting them.
Thanks for these! Looking forward to checking them out! Will report back.
These are great. Thanks for sharing @bobritsky
Much appreciated, that hammond sounds amazing!
Thanks a lot mate! Cheers
Great!!
First of all, thanks for sharing!
I’m having a hard time getting these to work on my OP-1. It always says “failed to create synth patch”.
All I did was:
- Download
- Copied all files into a fresh folder called “bobs-neo-soul”
- Turned OP-1 to DISK mode and copied the folder into the synth folder
When restarting, only the “Rhodes Chorus” patch is created, while all other fail.
I also tried to rename them without any luck.
First of all, thanks for sharing!I'm having a hard time getting these to work on my OP-1. It always says "failed to create synth patch".All I did was:- Download- Copied all files into a fresh folder called "bobs-neo-soul" :)- Turned OP-1 to DISK mode and copied the folder into the synth folderWhen restarting, only the "Rhodes Chorus" patch is created, while all other fail.I also tried to rename them without any luck.
Your patch memory is full
Yes, must probably full memory causes your error. You can free it by deleting some files from synth folder.
second - I dont recommend to put imported files into folders (especcially such long named
just copy them to synth folder
Thanks @bobritsky
It seems like there is a problem with the links, impossible to download the files.
Please, could you upload them again? I’m really interested in those kind of sounds.
thanks for that bobritsky
