I can also run the same sample through a SP404SX to compare if you likeOoh yeah! That would be awesome... Probably future people will be interested too, so I'll just share the folder here if anyone else wants to use the same samples, they should be re-uploadable to the same folder... I might just clean up the filenames now... The vocal choir sample is mine just from the other day's tracking, but feel free to use it, just attribute me somehow if you put something out with it. I guess if anyone wants to process these samps with anything, feel free, just append the effect & quick description to the filename, and if it gets messy, I'll make subfolders for each effect type or something. I'll probably start a new thread named "vinyl sim comparison (plus other effects" or something... If anyone thinks the 6 samples I uploaded would be more useful to be different kinds, then I'm happy to consider changing them, or maybe one single audio file with the different samples within would be way easier... My rationale behind my choices is as follows:
So, the long file thing will probably be much easier, should be real easy to import before and after into your DAW of choice, and A/B away… Here is a place to drop everything
@ludicrouSpeed Nice mix of samples man, I just uploaded SP404 vinyl sim versions to the comparison fx folder.
@ludicrouSpeed Nice mix of samples man, I just uploaded SP404 vinyl sim versions to the comparison fx folder.I looped up each sample so I could mess with all the vinyl sim parameters. The first and last loop of each file is the dry original version, and each time it loops I'm changing the compression amount, vinyl crackles and the flutter knob, as well as changing the input levels to show how the compressor reacts to it.
Dude, thankyou SO MUCH!
No worries mate! Yeah that vinyl sim compressor is special, sounds good on everything, even as a master effect. I use the flutter a bit, but always have the crackles turned off as don’t like the sound of them.
Remember the 505 also has the OG Vinyl Compression too! Can pick them up cheap if you’re patient
Thanks mate! Yeah, I heard that 404 is close to 505, and 303 too, but 303 is a bit dirtier, but could be cause of sampling rates or what have you… I think I’d prefer 404 on account of it’s smaller size, but maybe they’re close.
If anybody needs a Boss SP 505…
If anybody needs a Boss SP 505...I am selling one without powerchord for 200$ inlcuding worldwide shipping.sorry for hijacking :)
Which $?
Also, how about the physical size of the 505 vs the 303/404… Finding it hard to find comparison pics.
Hi,
Hi,American dollars it is...In terms of size the 505 is 12cm wider than the 404. Depth is the same as 404, but it slimmer in terms of heigth. Is that understandable?If you want I could take some pics tomorrow...got a 404 and 505 here.
Thanks mate, it’s all good. I don’t think I can justify the purchase just now.
How would you compare the vinyl sim to the 404og or 303?
No problem…
I love my 505! The micro editor is so useful.
