I’ve just gone out and bought a portable Bluetooth speaker to connect to my OP-Z, but only to find out you can’t connect them via Bluetooth. Is that correct?
Do I need a speaker that has a 3.5mm jack or something else? It would seem that the majority of modern speakers are Bluetooth only.
I would recommend the JBL bluetooth speaker line. While you can’t connect your op-z to it over bluetooth you can sync multiple speakers over bluetooth. The sound quality is good enough for me and there are several different sizes available.
A friend of mine is into FPV drones and invited me to come hang out at a meetup. We were in an abandoned cement factory that was covered in graffiti. One piece was a speaker box on a old stump of concrete. It looked like the perfect place so to set up the speaker and op-z for a jam. A couple other people there also JBL speakers. One smaller and one larger. They synced the other two to my speaker that the op-z was plugged into and the sound filled up the space well.
The down side is there is a slight bit of lag. The speakers audio is in sync, but there is a slight lag from the device to the speakers when multiple speakers are synced over Bluetooth. It’s a problem when scratching with a portable turntable or trying to play drums or a melody live, but if you are just playing back pre-made loops it’s totally fine. I can use the lights on the op-z to judge timing for punch in fx. Sequencing a new beat with the lag is fine, but playing in live is a no go.
Check out my instagram post on the day. Click the link to go to instagram and to see all the pics from the day.
