Is it true that pocket operators can only be synced to stay in time but not return to the beginning of the same pattern after being stopped? I’m looking to sync them with other midi equipment and was hoping there was some way to bring them back to the beginning of any pattern one they’re stopped.
Yeah the sync feature will only stop/ start/ tempo sync. When you press play on the “master” po once the “slave” is armed they will both play, you can pause the slave and restart it, I think functioning as a mute of sorts, and if you pause the master they both stop, and will restart from the top when you press play again.
Please someone correct me if I’m wrong.
