Stillwater 1.1 beta (OP-XY has a new friend)
Hi everyone,
First, a huge thank you to everyone who has been testing Stillwater so far. You haven’t just been finding bugs. Your ideas and suggestions for new shortcuts have made this app a much better experience, and a lot of what’s in the newest build came straight from you.
If you haven’t joined yet, I’ve just opened the TestFlight to 250 more testers:
What Stillwater is for
Stillwater was made for generative ambient. Set up a few synths, give them a sequencer, let the loopers catch what you play, and it keeps evolving on its own. It’s just as good when you want to sit and jam along with it, or take it out for a live set: everything is a tap away, nothing hides behind menus, and it’s built to be played, not programmed.
Ito
Ito has been super fun to make, but it’s also taken the longest to get right. As a huge Make Noise fanboy, I wanted something like the Morphagene, and Ito is super close. Record something or load any sound, cut it into splices and play it in pieces. Push Morph up high and it starts layering pieces and throwing some of them up a fifth or an octave.
OP-XY presets
Importing OP-XY sampler and multisample presets also took a lot of work to get right, but now it’s super easy and only a button push. And this is only the beginning of the OP-XY and Stillwater friendship. I’m working on making them the perfect combination. Soon you’ll be able to design your own sounds in Stillwater, turn them into a multisample, and send it to your OP-XY with a click.
Price
As always, I’m keeping this affordable. Stillwater will start at $9.99 and will include many sounds from my preset packs.
And the best for last: Stillwater Tape —
"Stillwater is where ideas start: the generative patches, the jams, the live sets. Stillwater Tape is where they become finished pieces. It does everything Stillwater does, and then adds a whole studio around it, still in the same calm, hand-painted world.
An 8-track tape. Inspired by the OP-1’s tape, laid out so you always see where you are. Arm as many tracks as you like and record them all in one pass, each from its own source: a synth, a sequencer, one of the loopers. Overdub on top or replace, loop a section and keep layering, count yourself in with the metronome. Then edit it like tape: cut, copy and paste pieces, pick a recording up and drag it along the tape or onto another track, zoom in, and undo when you need to. When you’re done, export the whole mix or every track as its own stem.
A piano roll. Write and shape MIDI note by note, with eight patterns per synth that you can switch right away, on the next bar, or when the current loop finishes, just like launching scenes live. One-tap tools reshape what you’ve written, and when a part is right, Bounce records it down to the tape track of your choice in a single pass.
Your other apps, inside Stillwater. Load the AUv3 instruments and effects you already own (Moog, Arturia, FabFilter and more) right into Stillwater’s synth slots. Give each synth its own, run several at once, put effects on any mixer strip or the master, or swap one in for any of the sends. Their screens open as floating windows, and it all saves with your scene.
One mixer for everything. Synths, loopers and all eight tape tracks, with sends on one page.
The idea is simple: you shouldn’t have to leave Stillwater to finish a song. Start with a drifting generative patch, catch the best moments, and build them into something whole, all in one place."
Stillwater Tape will come with 3 GB of my samples and multisamples, and it will start at $24.99. And if you’d rather just try Stillwater first, no problem: you can start with Stillwater at $9.99 and upgrade to Stillwater Tape any time with a one-time upgrade of $15, so you never pay twice.
I can’t wait to share more about it soon.
Thanks again for being part of this.
John (Colors In Space)
Hey everyone,
First off, a huge thank you to everyone who’s been testing Stillwater.
So many of you have written in with bugs, ideas and little things that bugged you, and honestly a lot of what’s in the app now came straight from those emails.
I read every one of them. It’s made Stillwater a much better app than it would’ve been if I’d built it alone in a room.
If you haven’t jumped in yet, there’s still room. The beta has a couple hundred more openings, so if you’ve got an iPad and want to try it before it’s out, here’s the link:
The full version is with Apple right now and will be out very soon.
It was approved, but I had to fix a few bugs you guys found at the last minute.
But what I’m really excited about is 1.1.
I’ve been working on it nonstop, and it’s turned into something much bigger than I planned.
A lot of you own an OP-XY, so this one’s for you.
繋 Tsunagi: the OP-XY machine
Pick Tsunagi as a machine on any synth slot, plug your OP-XY into your iPad over USB, and tap Connect.
Stillwater sets up the MIDI and the OP-XY’s multichannel USB audio for you, with no AUM and no routing.
All of your OP-XY’s tracks come straight into Stillwater, ready to mix, add effects to and record.
Mixer: each of the OP-XY’s tracks comes in on its own channel, with its own fader, pan and sends to four effects, and meters that light up as each track plays.
Four effects, each with its own presets you can step through and save:
Fireflies: a granular effect built on Mutable Instruments Beads. It turns your OP-XY into clouds of grains, with size, density, spray, feedback, reverb and Freeze, which holds a moment in the air forever.
Space: a lush reverb from the Clouds firmware (Parasites), with shimmer for that glowing, pitched-up halo.
Yamabiko (Echo): Stillwater’s own delay.
Loop: a Clouds-style looping delay shown as an old magnetic drum echo. It has pitch, freeze and reverse, and can sync to tempo.
揺 Eight LFOs that move almost everything:
4 Tsunagi LFOs move Tsunagi itself: every effect knob, every track’s volume and sends, the Scenes crossfader, and every control on the Reel.
Hold any knob, pick an LFO, and set how much. Each LFO can drive up to 16 knobs at once.
4 OP-XY LFOs reach inside your OP-XY over MIDI, on any track: the synth’s four parameters, filter cutoff, resonance and envelope amount, the amp and filter envelopes, the OP-XY’s own LFO settings, and volume and pan. That’s up to 16 moving connections at once.
Tempo-synced from 1/16 up to 16 bars, with shape, polarity and a separate amount on every connection.
EQ and Master: draw your own EQ curve on each track by dropping points on it, then shape the whole mix on the Master.
録 The Recorder: a multitrack tape machine for your OP-XY.
11 tracks: all 8 OP-XY tracks, each on its own lane, plus your effects, Stillwater itself and the Reel. Arm any of them and record them all at once.
A real tape machine face, with spinning reels, a flip counter and a VU meter on every track.
OP-1 Field-style editing: SPLIT the tape at the playhead, LIFT a piece out, and DROP it somewhere else.
Marks: drop numbered marks to find your spots, and remove them just as easily.
Loop a section: drag its gold edges right on the tape.
Overdub: record on top of what’s there, with Undo when a take goes wrong.
Tape SPEED, for half-speed and slowed-down tape moods.
Sync: recording can start with the OP-XY’s Play, or with Stillwater’s sequencers (Koi, Kumo, Loom, Meadow, Orbits or Tide).
Count-in and click, with the timeline in bars and beats from the OP-XY’s tempo.
Tape FX and EQ, heard as you record or play back.
Get around easily: pinch the timeline to zoom, slide it with two fingers, hold the arrows to wind fast, or spin a reel with your finger to scrub.
Export stems: every track as its own file, ready for your DAW.
Reel: a Morphagene-style tape page. Record onto one big wave, cut it into splices, then play with gene size, slide, morph, speed, grains, reverse and freeze. It has its own mixer channel.
Stillwater’s sequencers play your OP-XY: each of Stillwater’s six sequencers can play an OP-XY track.
Rings: a Euclidean sequencer whose spinning rings play your OP-XY tracks.
Scenes: an Octatrack-style A/B crossfader. Lock your OP-XY’s synth and filter settings into scenes, slide between them, and save your sets.
Mac too: the Mac app talks to the OP-XY just like the iPad does.
重 Kasane and new sounds
重 Kasane (layers): kind of like the Combinator in Reason. 2 or 3 synths are played as one sound, stacked, split across the keys, or split by touch, with a live Blend between them. It comes with 50 presets.
Kasane’s mountain scene: play the sky with your fingers. The ridges glow and the mist follows Blend. You get a SLIDE bar and a GLIDE / STEPS switch, and it follows the Octave buttons.
Random Kasane: builds a brand-new sound from 2 or 3 random synths every tap, the Sampler and Multi-sample included, kept ambient and in key. I’ve lost hours to this button.
Kasane is the default: a new Stillwater opens right on the mountains.
Performing
動 Six Motion recorders: record your playing, slides and every dial you move. Each loops at its own length, so they drift against each other, and each one clears separately.
Motion saves with your scenes.
移 Morph: tap LEARN, tap any dials, and slide between 8 scenes with an A/B fader. It has 195 presets, Happy Accident, and AUTO, which moves the fader on its own.
Loop effect in Stillwater too: the same Clouds-style looping delay.
Sound design
Dice on every synth: one tap randomizes the whole synth, ambient-safe and in key.
Undo and Redo: for the dice, Random and Morph.
Save your own Kasanes: sample layers keep their sound too.
Easier to use
Flick-scroll preset lists: smooth finger scrolling through all ~700 presets.
Swipe to delete presets, with a one-tap bring-back.
Welcome cards and a Tips & Tricks page.
Plus a bunch of fixes and smoothing out.
Mac: the standalone Mac app is running with all of this too. It’ll come out once the VST version is ready.
